It is currently Thu Aug 14, 2025 10:32 pm
PostPosted: Sun Mar 22, 2015 4:13 am
First name: robin
Last Name: courtenay
City: andover
State: hants
Country: uk
Is the best way to do this,tape in place then wick in thin CA glue? Opinions and other methods would be appreciated.All the best Roby.
PostPosted: Sun Mar 22, 2015 7:03 am
Really have nothing good to say about CYA for celluloid binding. I use Weldon 16 and find it to be more sticky than Duco cement. CYA will wick into the purfling and turn it yellow under the finish.
PostPosted: Sun Mar 22, 2015 2:29 pm
What he said.
PostPosted: Mon Mar 23, 2015 9:10 am
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
I've used CA with ivoroid many times with no problem or yellowing. I do it just like you describe...tape in place and drop thin CA. Then hit it with the activator to get a fast cure. CA will soften/dissolve celluloid binding if left wet too long...more than a few seconds, so spray activator as you go. Get a glue pipette or syringe too, drops from the bottle tip are way too big and will wick everywhere
PostPosted: Mon Mar 23, 2015 1:22 pm
First name: robin
City: andover
State: hants
Country: uk
Thanks for the advice,Hans,is Weldon 16 good for wood purfling?
PostPosted: Mon Mar 23, 2015 3:54 pm
First name: Jason
Last Name: Moe
City: LaCrosse
State: WI
Zip/Postal Code: 54601
I have used 3M Plastic and Emblem adhesive for Plastic and Ivoroid binding. Its clear and is tough stuff. You can find it at your local auto parts store.
Jason Moe
LaCrosse WI 54601
PostPosted: Tue Mar 24, 2015 7:31 am
Roby, Weldon 16 is for the binding. I use white/yellow glue for purfling.
Users browsing this forum: Dmaxwell, pkdz and 14 guests
